ArcGIS.Desktop.Framework.Contracts Namespace / Pane Class
    Pane Class Properties
    For a list of all members of this type, see Pane members.
    Public Properties
     NameDescription
    Public Property Gets or sets whether the window may be closed.
    Public Property Gets or sets the Pane's caption.
    Public Property Allows derived classes to provide a unique identifier for the Pane. The DAML ID is returned by default.
    Public PropertyGets or sets the supplementary text that appears with the Tooltip only when the command is disabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a boolean to specify whether the control is enabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the Pane's Caption including its GroupID count.
    Public Property Gets the index assigned for the GroupID count.
    Public Property Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets a boolean indicating whether the pane has been fully initialized or not. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Public Property Gets the Framework assigned ID.
    Public Property Gets a boolean to let clients know the Pane is currently processing a Task.
    Public Property Gets or sets the large representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the message presented while the Pane is initializing.
    Public Property Gets the OperationManager associated with the Pane.
    Public Property This is for Esri internal use only.
    Public Property Gets or sets the small representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the Pane's state table.
    Public Property Gets or sets the Pane's tab tooltip.
    Public Property Gets or sets the Pane's HwndHost if applicable.
    Public Property Gets or sets a brief description of the command that appears in a small pop-up window when a user pauses the mouse pointer over an element, such as over a Button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a one or two word label that appears above the tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Top
    Protected Properties
     NameDescription
    Protected Internal Property Gets or sets the content portion of the Pane.
    Protected Internal Property Setting the GroupID property enables Pane numbering.
    Protected Internal Property For internal esri use only
    Top
