ArcGIS.Desktop.Framework.Contracts Namespace / Pane Class
    Pane Class Methods
    For a list of all members of this type, see Pane members.
    Public Methods
     NameDescription
    Public Method Makes the Pane the active Pane and active window.
    Public Method Close the Pane.
    Public Method Flashes the Pane's tab.
    Public Method Invoked when an object is dragged over the window. Implement this method to add class handling for this event. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Public Method Invoked when an object is dropped onto the pane. Implement this method to add class handling for this event. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Top
    Protected Methods
     NameDescription
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Copy button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's CopyPath button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Cut button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Delete button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Duplicate button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Paste button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's PasteSpecial button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Combines the Pane's state with the specified Pane.
    Protected Internal Method Called when the Copy command is clicked. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the CopyPath command is clicked. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the Cut command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the Delete command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the Duplicate command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Method Allows a Pane to override the state it sets when activated.
    Protected Internal Method Called when the pane is first created to give it the opportunity to initialize itself asynchronously. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Protected Internal Method Called whenever the Pane is activated or deactivated.
    Protected Internal Method Notification letting the Pane know it has been closed.
    Protected Internal Method Called when a request has been made to close the Pane.
    Protected Internal Method Provides the Pane with the option to customize its ContextMenu before it is displayed.
    Protected Internal Method Optional override to create the visible content of the control.
    Protected Internal Method Notification letting the Pane know it has been docked.
    Protected Internal Method Occurs when a mouse button is clicked two or more times.
    Protected Internal Method Notification letting the Pane know it has been floated.
    Protected Internal Method Notification letting the Pane know it has been hidden.
    Protected Internal Method Called during OnKeyDown if when a register shortcut matches. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Occurs when a key is pressed while focus is on this element.
    Protected Internal Method Occurs when a key is released while focus is on this element.
    Protected Internal Method Occurs when any mouse button is pressed while the pointer is over this element.
    Protected Internal Method Occurs when the mouse pointer moves while over this element.
    Protected Internal Method Occurs when any mouse button is released over this element.
    Protected Internal Method Occurs when a pointer is pressed while over this element.
    Protected Internal Method Occurs when a pointer is released over this element.
    Protected Internal Method Occurs when a touch event occurs over this element.
    Protected Internal Method Called periodically by the framework once the tool has been created. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Protected Internal Method Called when the Paste command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the PasteSpecial command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Method Process key down
    Protected Method Stops the Pane from impersonating a different state.
    Protected Internal Method Called when the pane is closed to give it the opportunity to uninitialize itself asynchronously. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Top
