ArcGIS.Desktop.Framework.Contracts Namespace / ShortCut Class
    ShortCut Class Properties
    For a list of all members of this type, see ShortCut members.
    Public Properties
     NameDescription
    Public Property Gets a boolean indicating whether this short-cut should be canceled if mouse moves. This is only evaluated if ExecutesOnKeyUp is true. The default value is false.
    Public Property Gets the command ID associated with this short-cut.
    Public Property Gets the display string associated with this short-cut.
    Public Property Gets a boolean indicating whether this short-cut should be executed on key up. The default value is false.
    Public Property Gets a boolean indicating whether this shortcut is disabled.
    Public Property Gets a boolean indicating whether this shortcut is removed.
    Public Property Gets the key associated with this short-cut.
    Public Property Gets the modifier keys associated with this short-cut.
    Top
