Public NotInheritable Class LayoutProjectItem Inherits ArcGIS.Desktop.Internal.Core.ProjectItem Implements ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
public sealed class LayoutProjectItem : ArcGIS.Desktop.Internal.Core.ProjectItem, ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
Each Layout in a project is associated with a LayoutProjectItem. This item contains numerous read-only metadata properties about the layout. Although a layout may exist in the project, it may not be loaded (an open layout view). To reference the actual layout and ensure it is loaded into memory, you must use the GetLayout method.
LayoutProjectItem layoutProjItem = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(item => item.Name.Equals("myLayout"));
// Use layoutProjItem;
//Gets all the layouts in the current project
IEnumerable<LayoutProjectItem> projectLayouts = Project.Current.GetItems<LayoutProjectItem>();
foreach (var layoutItem in projectLayouts)
//Do Something with the layout
//GetItems searches project content
var map = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(m => m.Name == "Map1");
var layout = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(m => m.Name == "Layout1");
var folders = Project.Current.GetItems<FolderConnectionProjectItem>();
var style = Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 3D");
//Find item uses a catalog path. The path can be to a file or dataset
var fcPath = @"C:\Pro\CommunitySampleData\Interacting with Maps\Interacting with Maps.gdb\Crimes";
var pdfPath = @"C:\Temp\Layout1.pdf";
var imgPath = @"C:\Temp\AddinDesktop16.png";
var fc = Project.Current.FindItem(fcPath);
var pdf = Project.Current.FindItem(pdfPath);
var img = Project.Current.FindItem(imgPath);
LayoutProjectItem layoutItemByName = Project.Current.GetItems<LayoutProjectItem>()
.FirstOrDefault((lpi) => lpi.Name == "MyLayout");
//Note: Needs QueuedTask to run
Layout layoutByName = layoutItemByName.GetLayout();
//Reference layout project items and their associated layout.
//A layout project item is an item that appears in the Layouts
//folder in the Catalog pane.
//Reference all the layout project items
IEnumerable<LayoutProjectItem> layoutProjectItems =
//Or reference a specific layout project item by name
LayoutProjectItem specificLayoutItem = Project.Current.GetItems<LayoutProjectItem>()
.FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
//Open a layout project item in a new view.
//A layout project item may exist but it may not be open in a view.
//Reference a layout project item by name
//Get the layout associated with the layout project item
Layout layoutFromItem = layoutItemByName.GetLayout(); //Worker thread
//Create the new pane - call on UI
ILayoutPane iNewLayoutPane = await ProApp.Panes.CreateLayoutPaneAsync(layout); //GUI thread
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Core.Item
ArcGIS.Desktop.Layouts.LayoutProjectItem
