ArcGIS.Desktop.Mapping Namespace / StyleItemType Enumeration
Example Example
    Specifies the type of StyleItem.
    Syntax
    Members
    MemberDescription
    AreaLegendPatch An area legend patch, small rectangles used to display legend classes.
    Color A single color defined by values in a supported color model.
    ColorRamp An array of colors in a specified pattern or scheme.
    DimensionStyle A style used to draw Dimension features.
    Grid A grid layout element.
    Legend A legend layout element.
    LegendItem A legend item layout element.
    LineLegendPatch A line legend patch, small lines used to display legend classes
    LineSymbol A symbol to draw line features.
    MaplexLabelPlacement A set of rules based on the Maplex label engine determining how labels will be placed in relation to features.
    MapSurround A map surround layout element (excludes surrounds with their own type e.g. North Arrow).
    MeshSymbol A symbol to draw multipatch features.
    NorthArrow A directional layout element used to indicate north orientation.
    PointSymbol A symbol to draw point features.
    PolygonSymbol A symbol to draw polygon features.
    ScaleBar A layout element that graphically indicates map scale.
    StandardLabelPlacement A set of rules based on the standard label engine determining how labels will be placed in relation to features.
    TableFrame A table frame layout element.
    TableFrameField A table frame field layout element.
    TextSymbol A symbol to draw labels or annotation features.
    Unknown A generic, unspecified style item.
    Remarks
    StyleItem class.
    Example
    Create Line Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      List<Coordinate2D> plCoords = new List<Coordinate2D>();
      plCoords.Add(new Coordinate2D(1, 8.5));
      plCoords.Add(new Coordinate2D(1.66, 9));
      plCoords.Add(new Coordinate2D(2.33, 8.1));
      plCoords.Add(new Coordinate2D(3, 8.5));
      Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
      //Reference a line symbol in a style
      var ProjectStyles = Project.Current.GetItems<StyleProjectItem>();
      StyleProjectItem style = ProjectStyles.First(x => x.Name == "ArcGIS 2D");
      var symStyle = style.SearchSymbols(StyleItemType.LineSymbol, "Line with 2 Markers")[0];
      CIMLineSymbol lineSym = symStyle.Symbol as CIMLineSymbol;
      lineSym.SetSize(20);
      //Set symbology, create and add element to layout
      //CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
      ElementFactory.Instance.CreateGraphicElement(
        layout, linePl, lineSym, "New Line");
    Create Point Element
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
      //Reference a point symbol in a style
      StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
                .FirstOrDefault(item => item.Name == "ArcGIS 2D");
      SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
                            StyleItemType.PointSymbol, "City Hall")[0];
      CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
      pointSym.SetSize(50);
      var elemInfo = new ElementInfo()
        CustomProperties = new List<CIMStringMap>() {
        new CIMStringMap() { Key = "Key1", Value = "Value1"},
        new CIMStringMap() { Key = "Key2", Value = "Value2"}
        Anchor = Anchor.TopRightCorner,
        Rotation = 45.0
      var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
                                    coord2D.ToMapPoint(), pointSym);
        layout, graphic, "New Point", true, elemInfo);
    How to apply a point symbol from a style to a feature layer
          //Get the ArcGIS 2D System style from the Project
          var arcGIS2DStyle =
    Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
          //Note: Needs QueuedTask to run
          //Search for the symbolName style items within the ArcGIS 2D style project item.
          var items = arcGIS2DStyle.SearchSymbols(StyleItemType.PointSymbol, "Circle 1");
          //Gets the CIMSymbol
          CIMSymbol symbolToUse = items.FirstOrDefault().Symbol;
          //Get the renderer of the point feature layer
          CIMSimpleRenderer renderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
          //Set symbol's real world setting to be the same as that of the feature layer
          symbolToUse.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
          //Apply the symbol to the feature layer's current renderer
          renderer.Symbol = symbolToUse.MakeSymbolReference();
          //Apply the renderer to the feature layer
          featureLayer.SetRenderer(renderer);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.StyleItemType
    Requirements
