ArcGIS.Desktop.Mapping Namespace / Animation Class
Members Example
    Animation Class
    Represents the collection of tracks, keyframes and transitions that define an animation for the map.
    Syntax
    Public NotInheritable Class Animation
    public sealed class Animation
    Remarks
    Animation is the process of creating a collection of sequential images and playing them back quickly to create an illusion of movement. Each image, just like a picture you take with a camera, marks a significant instance in time, and is called a keyframe. In ArcGIS Pro, animations are authored by defining a set of keyframes that the system uses to create interpolated intermediate frames. Animations can interpolate the camera position, map time, map range, and layer visibility and transparency.
    An instance of this class is returned from the Map.Animation property and can be used to manipulate the state of the animation by creating, editing and deleting keyframes.
    Example
    Set Animation Length
      var animation = mapView.Map.Animation;
      var duration = animation.Duration;
      if (duration == TimeSpan.Zero)
        return;
      var factor = length.TotalSeconds / duration.TotalSeconds;
      animation.ScaleDuration(factor);
    Scale Animation
      if (duration == TimeSpan.Zero || duration <= afterTime)
        // Nothing to scale, leave
      var factor = length.TotalSeconds / (duration.TotalSeconds - afterTime.TotalSeconds);
      animation.ScaleDuration(afterTime, duration, factor);
    Camera Keyframes
      var cameraTrack = animation.Tracks.OfType<CameraTrack>().First(); //There will always be only 1 CameraTrack in the animation.
      var result = cameraTrack.Keyframes.OfType<CameraKeyframe>().ToList();
      //Use the camera keyframes (if any)
    Create Camera Keyframe
      cameraTrack.CreateKeyframe(mapView.Camera, atTime, AnimationTransition.FixedArc);
    Create Time Keyframe
      var timeTrack = animation.Tracks.OfType<TimeTrack>().First(); //There will always be only 1 TimeTrack in the animation.
      timeTrack.CreateKeyframe(mapView.Time, atTime, AnimationTransition.Linear);
    Create Range Keyframe
      var rangeTrack = animation.Tracks.OfType<RangeTrack>().First(); //There will always be only 1 RangeTrack in the animation.
      rangeTrack.CreateKeyframe(range, atTime, AnimationTransition.Linear);
    Create Layer Keyframe
      var layerTrack = animation.Tracks.OfType<LayerTrack>().First(); //There will always be only 1 LayerTrack in the animation.
      layerTrack.CreateKeyframe(layer, atTime, true, transparency, AnimationTransition.Linear);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.Animation
    Requirements
