ArcGIS.Desktop.Mapping Namespace / ExportFormat Class
Members Example
    ExportFormat Class
    Provides a base set of properties that all export formats inherit.
    Syntax
    Public Class ExportFormat
    public class ExportFormat
    Remarks
    When exporting a MapView, the size of the output image is based on the Resolution and the Height and Width properties. For example, if the output resolution is 96 and height and width are both 960 then the output image size will be 960 pixels by 960 pixels and 10 inches by 10 inches. The geographic area for an exported MapView is generated based on its Camera location which represents the center of the view.
    When exporting a Layout or a MapFrame, the height and width are obtained from the size of the object in page units and the Height and Width properties are ignored. For example, if a MapFrame is 5 inches by 5 inches and the resolution is 300, the output image will be 1500 pixels by 1500 pixels and remain 5 inches by 5 inches.
    Example
    Export a layout to PDF
      //Export a single page layout to PDF.
      //Create a PDF format with appropriate settings
      //BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
      string filePath = @"Path and file name for the output export file";
      PDFFormat PDF = new PDFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        DoCompressVectorGraphics = true,
        DoEmbedFonts = true,
        HasGeoRefInfo = true,
        ImageCompression = ImageCompression.Adaptive,
        ImageQuality = ImageQuality.Best,
        LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
      //Check to see if the path is valid and export
      if (PDF.ValidateOutputFilePath())
        //Note: Must be on QueuedTask.Run
        layout.Export(PDF);  //Export the layout to PDF on the worker thread
    Export a map frame to JPG
      //Export a map frame to JPG.
      //Create JPEG format with appropriate settings
      //BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      JPEGFormat JPG = new JPEGFormat()
        HasWorldFile = true,
        Resolution = 300,
        ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
        Height = 800,
        Width = 1200
      //Reference the map frame
      MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
      //Export on the worker thread
      //Note: Must be on QueuesTask.Run
      if (JPG.ValidateOutputFilePath())
        mf.Export(JPG);  //Export the map frame to JPG
    Export the map view associated with a map frame to BMP
      //Export the map view associated with a map frame to BMP.
      //Create BMP format with appropriate settings
      //EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      BMPFormat BMP = new BMPFormat()
        Resolution = 300,
        Height = 500,
        Width = 800,
      await QueuedTask.Run(() =>
        MapView mv_bmp = mapFrame.GetMapView(layoutView);
        if (mv_bmp != null)
          if (BMP.ValidateOutputFilePath())
            mv_bmp.Export(BMP);  //Export to BMP
    Export a map series to single PDF
      //Export a map series with multiple pages to a single PDF.
      //Create PDF format with appropriate settings
      PDFFormat MS_PDF = new PDFFormat()
        Resolution = 300,
      //Set up map series export options
      MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
        ExportPages = ExportPages.Custom,  //Provide a specific list of pages
        CustomPages = "1-3, 5",  //Only used if ExportPages.Custom is set
        ExportFileOptions = ExportFileOptions.ExportAsSinglePDF,  //Export all pages to a single, multi-page PDF
        ShowSelectedSymbology = false  //Do no show selection symbology in the output
      if (MS_PDF.ValidateOutputFilePath())
        layout.Export(MS_PDF, MS_ExportOptions);  //Export to PDF
    Export a map series to individual TIFF files
      //Export each page of a map series to an individual TIFF file.
      //Create TIFF format with appropriate settings
      TIFFFormat TIFF = new TIFFFormat()
        Resolution = 300,
        ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
        HasGeoTiffTags = true,
        ImageCompression = TIFFImageCompression.LZW
      MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
        ExportPages = ExportPages.All,  //All pages
        ExportFileOptions = ExportFileOptions.ExportMultipleNames,  //Export each page to an individual file using page name as a suffix.
        ShowSelectedSymbology = true  //Include selection symbology in the output
      //Note: Must be on the QueuedTask.Run()
      if (TIFF.ValidateOutputFilePath())
        layout.Export(TIFF, MSExportOptions_TIFF);  //Export to TIFF
    Inheritance Hierarchy
    Requirements
