ArcGIS.Desktop.Mapping Namespace / GroupLayer Class
Members Example
    GroupLayer Class
    Represents a layer containing an editable collection of layers.
    Object Model
    GroupLayer ClassLayer ClassStandaloneTable ClassCIMDataConnection ClassTimeExtent ClassCIMBaseLayer ClassElevationTypeDefinition ClassSpatialReference ClassTimeParameters ClassSurfaceZsResult ClassMap ClassILayerContainer InterfaceEnvelope Class
    Syntax
    Remarks
    To create a GroupLayer, you must call CreateGroupLayer() method of the LayerFactory class, instead of directly using a constructor.
    Example
    Remove empty groups
        //Get the group layers
        IReadOnlyList<GroupLayer> groupLayers = map.Layers.OfType<GroupLayer>().ToList();
        //Note: Run within a QueuedTask
        foreach (var group in groupLayers)
            if (group.Layers.Count == 0) //No layers in the group
                //remove the group
                map.RemoveLayer(group);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Mapping.MapMember
             ArcGIS.Desktop.Mapping.Layer
                ArcGIS.Desktop.Mapping.CompositeLayer
                   ArcGIS.Desktop.Mapping.CompositeLayerWithTables
                      ArcGIS.Desktop.Mapping.GroupLayer
    Requirements
