ArcGIS.Desktop.Mapping Namespace / MapFactory Class
    MapFactory Class Methods
    For a list of all members of this type, see MapFactory members.
    Public Methods
     NameDescription
    Public Method Determines whether the map can be converted to the specified output type. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Determine whether the map item can be converted to the specified output type. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Determines whether a map can be created from an Item.
    Public Method Convert the input map to the specified output type. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Convert the input map item to the specified output type. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Copies the input map and adds it to the project. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Public MethodCreates a local basemap of MapType.Basemap ArcGIS.Core.CIM.MapType. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Creates a new Map in the project using an item e.g. webmap, mxd etc. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Creates a new Map in the project. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodCreates a map of type MapType.Scene ArcGIS.Core.CIM.MapType with a specified ground elevation source. This method must be called on the MCT. Use QueuedTask.Run.
    Top
