ArcGIS.Desktop.Mapping Namespace / MapView Class / GetFeatures Method
The geometry used to identify features that intersect it.
Indicates whether only features that visibly intersect the geometry should be returned.
This parameter only applies to 2D. Indicates whether only features that are completely within the geometry should be returned.
Example
    GetFeatures Method
    Return features that intersect a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetFeatures( _
       ByVal geometry As Geometry, _
       Optional ByVal visualIntersect As Boolean, _
       Optional ByVal whollyWithin As Boolean _
    ) As SelectionSet
    Parameters
    geometry
    visualIntersect
    whollyWithin
    Return Value
    The collection of layers and object ids that intersect the geometry.
    Exceptions
    ExceptionDescription
    3D views only support selecting features interactively using geometry in screen coordinates relative to the top-left corner of the view
    Example
    Create a tool to identify the features that intersect the sketch geometry
    internal class CustomIdentify : MapTool
      public CustomIdentify()
        IsSketchTool = true;
        SketchType = SketchGeometryType.Rectangle;
        //To perform a interactive selection or identify in 3D or 2D, sketch must be created in screen coordinates.
        SketchOutputMode = SketchOutputMode.Screen;
      protected override Task<bool> OnSketchCompleteAsync(ArcGIS.Core.Geometry.Geometry geometry)
        return QueuedTask.Run(() =>
          var mapView = MapView.Active;
          if (mapView == null)
            return true;
          //Get all the features that intersect the sketch geometry and flash them in the view.
          var results = mapView.GetFeatures(geometry);
          mapView.FlashFeature(results);
          var debug = System.String.Join("\n", results.ToDictionary()
                        .Select(kvp => System.String.Format("{0}: {1}", kvp.Key.Name, kvp.Value.Count())));
          System.Diagnostics.Debug.WriteLine(debug);
          return true;
    Requirements
