ArcGIS.Desktop.Mapping Namespace / MapView Class / SelectFeatures Method
The geometry used to select features that intersect it.
Combination method used in selection operation.
This parameter only applies to 3D. Indicates whether only features that visibly intersect the geometry should be selected.
This parameter only applies to 2D. Indicates whether only features that are completely within the geometry should be selected.
Example
    Select features that intersect a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function SelectFeatures( _
       ByVal geometry As Geometry, _
       Optional ByVal method As SelectionCombinationMethod, _
       Optional ByVal isVisualIntersect As Boolean, _
       Optional ByVal isWhollyWithin As Boolean _
    ) As SelectionSet
    Parameters
    geometry
    method
    isVisualIntersect
    isWhollyWithin
    Return Value
    The map selection created by the intersection with the geometry.
    Exceptions
    ExceptionDescription
    3D views only support selecting features interactively using geometry in screen coordinates relative to the top-left corner of the view.
    Example
    Change the layer selection color
        // get the CIM definition of the layer
        // Note: needs to be called on the MCT
        var layerDef = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
        // disable the default symbol
        layerDef.UseSelectionSymbol = false;
        // assign a new color
        layerDef.SelectionColor = ColorFactory.Instance.RedRGB;
        // apply the definition to the layer
        featureLayer.SetDefinition(layerDef);
        if (!featureLayer.IsVisible)
            featureLayer.SetVisibility(true);
        //Do a selection
        MapView.Active.SelectFeatures(MapView.Active.Extent);
    Requirements
