ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomTo Method / ZoomTo(Camera,Nullable<TimeSpan>) Method
The new camera to use for the view.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    Zoom the view to a camera position. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function ZoomTo( _
       ByVal camera As Camera, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Boolean
    Parameters
    camera
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    Remarks
    This is equivalent to setting the camera position for the view. Use this method in combination with Camera /> to get and then modify the position of the view's camera. If the camera's spatial reference is in a different spatial reference than the map this method projects the camera into the spatial reference of the map.
    Example
    Zoom to a specified point
      double x = -122.45;
      double y = 37.75;
      double buffer_size = 0.1;
      //Create a point
      var pt = MapPointBuilderEx.CreateMapPoint(x, y,
                     SpatialReferenceBuilder.CreateSpatialReference(4326));
      //Buffer it - for purpose of zoom
      var poly = GeometryEngine.Instance.Buffer(pt, buffer_size);
      //do we need to project the buffer polygon?
      if (!MapView.Active.Map.SpatialReference.IsEqual(poly.SpatialReference))
        //project the polygon
        poly = GeometryEngine.Instance.Project(poly, MapView.Active.Map.SpatialReference);
      // Must run on MCT.
      QueuedTask.Run(() =>
        //Zoom - add in a delay for animation effect
        MapView.Active.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Zoom To a Point
      // Note: Needs QueuedTask to run
        //Create a point
        var pt = MapPointBuilderEx.CreateMapPoint(x, y, spatialReference);
        mapView.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Rotate the map view
      //Get the camera for the view, adjust the heading and zoom to the new camera position.
      camera = mapView.Camera;
      camera.Heading = heading;
      await mapView.ZoomToAsync(camera, TimeSpan.Zero);
      //Or synchronously
      mapView.ZoomTo(camera, TimeSpan.Zero);
    Requirements
