ArcGIS.Desktop.Mapping Namespace / MapView Class / ViewingMode Property
Example
    ViewingMode Property (MapView)
    Gets the perspective of the view.
    Syntax
    Public ReadOnly Property ViewingMode As MapViewingMode
    public MapViewingMode ViewingMode {get;}
    Remarks
    This property is used to determine whether the view is displaying a 2D map or 3D scene. A map view can be used to show maps which display 2D data or scenes which display 3D data. For a 3D view SceneLocal and SceneGlobal are valid view modes for the scene.
    Example
    Test if the view is 3D
      //Determine whether the viewing mode is SceneLocal or SceneGlobal
      var result = mapView.ViewingMode == MapViewingMode.SceneLocal ||
                   mapView.ViewingMode == MapViewingMode.SceneGlobal;
      // Use the result variable as needed
    Check if a Voxel Layer can be created
      //Map must be a local scene
      bool canCreateVoxel = (MapView.Active.ViewingMode == MapViewingMode.SceneLocal);
      if (canCreateVoxel)
        //TODO - use the voxel api methods
    Requirements
