await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
QueryDef adaCompilantParksQueryDef = new QueryDef
Tables = "Park",
WhereClause = "ADACOMPLY = 'Yes'",
using (RowCursor rowCursor = geodatabase.Evaluate(adaCompilantParksQueryDef, false))
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
Feature feature = row as Feature;
Geometry shape = feature.GetShape();
String type = Convert.ToString(row["ADACOMPLY"]); // will be "Yes" for each row.
try
Table table = row.GetTable(); // Will always throw exception.
catch (NotSupportedException exception)
// Handle not supported exception.
QueryDef municipalEmergencyFacilitiesQueryDef = new QueryDef
SubFields = "EmergencyFacility.OBJECTID, EmergencyFacility.Shape, EmergencyFacility.FACILITYID, FacilitySite.FACILITYID, FacilitySite.FCODE",
Tables = "EmergencyFacility, FacilitySite",
WhereClause = "EmergencyFacility.FACNAME = FacilitySite.NAME AND EmergencyFacility.JURISDICT = 'Municipal'",
using (RowCursor rowCursor = geodatabase.Evaluate(municipalEmergencyFacilitiesQueryDef, false))
long objectID = Convert.ToInt64(row["EmergencyFacility.OBJECTID"]);
String featureCode = Convert.ToString(row["FacilitySite.FCODE"]);
IReadOnlyList<Field>
fields = feature.GetFields(); //Contains one ArcGIS.Core.Data.Field objects for every subfield
QueryDef queryDef = new QueryDef
Tables = "CommunityAddress JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
SubFields = "CommunityAddress.OBJECTID, CommunityAddress.Shape, CommunityAddress.SITEADDID, CommunityAddress.ADDRNUM, CommunityAddress.FULLNAME, CommunityAddress.FULLADDR, CommunityAddress.MUNICIPALITY, MunicipalBoundary.Name, MunicipalBoundary.MUNITYP, MunicipalBoundary.LOCALFIPS",
using (Geodatabase testVersion1Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
AuthenticationMode = AuthenticationMode.DBMS,
Instance = "instance",
User = "user",
Password = "password",
Database = "database",
Version = "user.testVersion1"
QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef)
Name = "CommunityAddrJounMunicipalBoundr",
PrimaryKeys = testVersion1Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
// Will be based on testVersion1.
using (Table queryTable = testVersion1Geodatabase.OpenQueryTable(queryTableDescription))
// Use queryTable.
using (Geodatabase testVersion2Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
User = "user",
Version = "user.testVersion2"
PrimaryKeys = testVersion2Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
// Will be based on testVersion2.
using (Table queryTable = testVersion2Geodatabase.OpenQueryTable(queryTableDescription))
// Use queryTable.
System.Object
ArcGIS.Core.Data.QueryDef
