ArcGIS.Core.Data Namespace / VirtualRelationshipClassDescription Class
Members Example
    Represents a mechanism to create a virtualRelationshipClass.
    Object Model
    VirtualRelationshipClassDescription ClassField ClassField Class
    Syntax
    Public NotInheritable Class VirtualRelationshipClassDescription
    public sealed class VirtualRelationshipClassDescription
    Example
    Joining a file geodatabase feature class to an Oracle database query layer feature class with a virtual relationship class
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("C:\\Data\\LocalGovernment.gdb"))))
        using (Database database = new Database(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
          AuthenticationMode = AuthenticationMode.DBMS,
          Instance = "instance",
          User = "user",
          Password = "password",
          Database = "database"
        using (FeatureClass leftFeatureClass = geodatabase.OpenDataset<FeatureClass>("Hospital"))
        using (Table rightTable = database.OpenTable(database.GetQueryDescription("FacilitySite")))
          Field originPrimaryKey = leftFeatureClass.GetDefinition().GetFields()
            .FirstOrDefault(field => field.Name.Equals("facilityId"));
          Field destinationForeignKey = rightTable.GetDefinition().GetFields()
            .FirstOrDefault(field => field.Name.Equals("hospitalID"));
          VirtualRelationshipClassDescription description = new VirtualRelationshipClassDescription(
            originPrimaryKey, destinationForeignKey, RelationshipCardinality.OneToOne);
          using (RelationshipClass relationshipClass = leftFeatureClass.RelateTo(rightTable, description))
            JoinDescription joinDescription = new JoinDescription(relationshipClass)
              JoinDirection = JoinDirection.Forward,
              JoinType = JoinType.LeftOuterJoin
            Join join = new Join(joinDescription);
            using (Table joinedTable = join.GetJoinedTable())
              // Perform operation on joined table.
    Joining two tables from different geodatabases
        using (Geodatabase sourceGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("Path \\ to \\Geodatabase \\ one"))))
        using (Geodatabase destinationGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("Path \\ to \\Geodatabase \\ two"))))
        using (Table sourceTable = sourceGeodatabase.OpenDataset<Table>("State"))
        using (Table destinationTable = destinationGeodatabase.OpenDataset<Table>("Cities"))
          Field primaryKeyField = sourceTable.GetDefinition().GetFields()
            .FirstOrDefault(field => field.Name.Equals("State.State_Abbreviation"));
          Field foreignKeyField = destinationTable.GetDefinition().GetFields()
            .FirstOrDefault(field => field.Name.Equals("Cities.State"));
          VirtualRelationshipClassDescription virtualRelationshipClassDescription = new VirtualRelationshipClassDescription(primaryKeyField, foreignKeyField,
              RelationshipCardinality.OneToMany);
          using (RelationshipClass relationshipClass = sourceTable.RelateTo(destinationTable, virtualRelationshipClassDescription))
              JoinType = JoinType.InnerJoin,
              TargetFields = sourceTable.GetDefinition().GetFields()
            using (Join join = new Join(joinDescription))
              Table joinedTable = join.GetJoinedTable();
              //Process the joined table. For example ..
              using (RowCursor cursor = joinedTable.Search())
                while (cursor.MoveNext())
                  using (Row row = cursor.Current)
                    // Use Row
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.VirtualRelationshipClassDescription
    Requirements
