ArcGIS.Desktop.Editing Namespace / TopologyProperties Class
Members Example
    Represents a base set of properties to define a topology option. See GeodatabaseTopologyProperties, MapTopologyProperties or NoTopologyProperties.
    Syntax
    Public MustInherit Class TopologyProperties
    public abstract class TopologyProperties
    Example
    Get List of available topologies in the map
    // Retrieves and processes the list of available topologies in the active map.
    await QueuedTask.Run(async () =>
      var map = MapView.Active.Map;
      //Get a list of all the available topologies for the map
      var availableTopologies = await map.GetAvailableTopologiesAsync();
      var gdbTopologies = availableTopologies.OfType<GeodatabaseTopologyProperties>();
      var mapTopologies = availableTopologies.OfType<MapTopologyProperties>();
    Get the properties of the active topology in the map
    // Retrieves the properties of the active topology associated with the specified map asynchronously.
    var activeTopologyProperties = await activeMap.GetActiveTopologyAsync();
    var isMapTopology = activeTopologyProperties is MapTopologyProperties;
    var isGdbTopology = activeTopologyProperties is GeodatabaseTopologyProperties;
    var isNoTopology = activeTopologyProperties is NoTopologyProperties;
    Inheritance Hierarchy
    Requirements
    ArcGIS Pro version: 3.1 or higher.
