ArcGIS.Core.Data Namespace / CoreDataExtensions Class / RemoveActivationExtension Method
The table from which the extension id will be removed
The extension id (guid) to be unregistered
Example
    Removes the extension id (guid) from being registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Syntax
    Public Shared Sub RemoveActivationExtension( _
       ByVal table As Table, _
       ByVal extensionId As Guid _
    public static void RemoveActivationExtension(
       Table table,
       Guid extensionId
    Parameters
    table
    extensionId
    Exceptions
    ExceptionDescription
    Value cannot be null: table
    extension id cannot be empty
    Remarks
    Removing an extension id (guid) from a table removes it from participating in whichever special behaviors were linked to the given id.
    Any backward compatibility removed by the extension id will be restored (depending on what other Geodatabase functionality is currently enabled and may additionally be limiting backwards compatibility).
    Activation extension ids are supported on registered classes in Enterprise, File, Mobile and on ArcObjects Feature Service geodatabases.
    Calling RemoveActivationExtension when the table is being edited will fail.
    Example
    Table Extension Ids
      // Must be called within QueuedTask.Run
      void ExtensionIds1(Table table)
        // Add an extension id to a table
        // Check documentation for restrictions on backward compatibility - backward
        // compatibility is limited to ArcGIS Pro 3.1 if an extension id is added.
        // Note: This is an extension method. It is for use in addins only and not CoreHost.
        string extension_id_string = "52d8f3be-b73d-4140-beaf-23d4f9b697ea";
        Guid extension_id = Guid.Parse(extension_id_string);
        // Note: Must be within the lambda of   QueuedTask.Run()
        // Register the extension id with the relevant table
        table.AddActivationExtension(extension_id);
        // Remove an extension id from a table
        // Restores backward compatibility assuming no other compatibility limitations are in place.
        table.RemoveActivationExtension(extension_id);
        // Check if a given extension id  is registered with a particular table.
        if (table.GetHasActivationExtension(extension_id))
          //Implement custom logic relevant to presence of extension_id ...
        // Enumerate all extension ids on a given table.
        foreach (Guid ext_id in table.GetActivationExtensions())
          // Logic based on extension ids ...
    Requirements
    ArcGIS Pro version: 3.1 or higher.
