ArcGIS.Core.Data Namespace / FileGeodatabaseConnectionPath Class
Members Example
    Represents the physical path to a file geodatabase folder that ends with the .gdb extension.
    Syntax
    Public NotInheritable Class FileGeodatabaseConnectionPath
       Inherits Connector
    public sealed class FileGeodatabaseConnectionPath : Connector
    Example
    Creating a File Geodatabase
      await QueuedTask.Run(() =>
        // Create a FileGeodatabaseConnectionPath with the name of the file geodatabase you wish to create
        FileGeodatabaseConnectionPath fileGeodatabaseConnectionPath =
          new FileGeodatabaseConnectionPath(new Uri(@"C:\Path-To-File-Geodatabase\YourName.gdb"));
        // Create and use the file geodatabase
        using (Geodatabase geodatabase =
               SchemaBuilder.CreateGeodatabase(fileGeodatabaseConnectionPath))
          // Create additional schema here
    Deleting a File Geodatabase
        // Create a FileGeodatabaseConnectionPath with the name of the file geodatabase you wish to delete
        // Delete the file geodatabase
        SchemaBuilder.DeleteGeodatabase(fileGeodatabaseConnectionPath);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.Connector
          ArcGIS.Core.Data.FileGeodatabaseConnectionPath
    Requirements
