ArcGIS.Core.Data Namespace / FileSystemDatastoreType Enumeration
Example Example
    Specifies the type of file-system data store.
    Syntax
    Members
    MemberDescription
    Cad CAD file.
    LasDataset LasDataset.
    Raster Raster.
    Shapefile Shapefile.
    Tin TIN.
    Example
    Opening a FeatureClass from a ShapeFile Datastore
      await QueuedTask.Run(() =>
        FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"),
            FileSystemDatastoreType.Shapefile);
        using (FileSystemDatastore shapefile = new FileSystemDatastore(fileConnection))
          FeatureClass taxLotsFeatureClass = shapefile.OpenDataset<FeatureClass>("TaxLots");
          // Can use the .shp extension, but its not needed.
          FeatureClass manHolesFeatureClass = shapefile.OpenDataset<FeatureClass>("ManHoles.shp");
          Table taxDetailsTableWithoutExtension = shapefile.OpenDataset<Table>("TaxDetails");
          Table taxDetailsTable = shapefile.OpenDataset<Table>("TaxDetails.dbf");
    Opening a CAD Datastore
        FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\CAD"), FileSystemDatastoreType.Cad);
        using (FileSystemDatastore cadDatastore = new FileSystemDatastore(fileConnection))
          //Note: Extension is required
          FeatureClass cadDataset = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg");
          // Take note of the pattern for referencing a feature class.
          FeatureClass cadfeatureClass = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg:Polyline");
          int numRows = 0;
          using (RowCursor cursor = cadfeatureClass.Search())
            while (cursor.MoveNext())
              numRows++;
    Open raster dataset in a folder
    // Create a FileSystemConnectionPath using the folder path.
    FileSystemConnectionPath connectionPath = new(new System.Uri(@"C:\Temp"), FileSystemDatastoreType.Raster);
    // Create a new FileSystemDatastore using the FileSystemConnectionPath.
    FileSystemDatastore dataStore = new(connectionPath);
    // Open the raster dataset.
    RasterDataset fileRasterDataset = dataStore.OpenDataset<RasterDataset>("Sample.tif");
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.FileSystemDatastoreType
    Requirements
