Parameters
- name
- The name of the dataset to open.
Type Parameters
- T
- The type of dataset to open.
| Exception | Description |
| System.InvalidOperationException | No valid file-system data store has been opened prior to calling this operation. -or- The dataset type corresponding to T is not supported (see DatasetType). |
| System.ArgumentException | name is null or an empty string. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. For example, the name is invalid. |
await QueuedTask.Run(() =>
FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"),
FileSystemDatastoreType.Shapefile);
using (FileSystemDatastore shapefile = new FileSystemDatastore(fileConnection))
FeatureClass taxLotsFeatureClass = shapefile.OpenDataset<FeatureClass>("TaxLots");
// Can use the .shp extension, but its not needed.
FeatureClass manHolesFeatureClass = shapefile.OpenDataset<FeatureClass>("ManHoles.shp");
Table taxDetailsTableWithoutExtension = shapefile.OpenDataset<Table>("TaxDetails");
Table taxDetailsTable = shapefile.OpenDataset<Table>("TaxDetails.dbf");
FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\CAD"), FileSystemDatastoreType.Cad);
using (FileSystemDatastore cadDatastore = new FileSystemDatastore(fileConnection))
//Note: Extension is required
FeatureClass cadDataset = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg");
// Take note of the pattern for referencing a feature class.
FeatureClass cadfeatureClass = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg:Polyline");
int numRows = 0;
using (RowCursor cursor = cadfeatureClass.Search())
while (cursor.MoveNext())
numRows++;
// Create a FileSystemConnectionPath using the folder path. FileSystemConnectionPath connectionPath = new(new System.Uri(@"C:\Temp"), FileSystemDatastoreType.Raster); // Create a new FileSystemDatastore using the FileSystemConnectionPath. FileSystemDatastore dataStore = new(connectionPath); // Open the raster dataset. RasterDataset fileRasterDataset = dataStore.OpenDataset<RasterDataset>("Sample.tif");
//Note: This snippet requires to be run on the MCT (Main CIM Thread)
string path = @"d:\Data\Tin";
var fileConnection = new FileSystemConnectionPath(new Uri(path), FileSystemDatastoreType.Tin);
using (FileSystemDatastore dataStore = new FileSystemDatastore(fileConnection))
// TIN is in a folder at d:\Data\Tin\TinDataset
string dsName = "TinDataset";
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(dsName))
//Do something with the dataset
//Note: Use QueuedTask.Run to run on the MCT
string path = @"d:\Data\LASDataset";
var fileConnection = new FileSystemConnectionPath(new Uri(path), FileSystemDatastoreType.LasDataset);
string name = "utrecht_tile.lasd"; // can specify with or without the .lasd extension
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.LasDataset>(name))
