ArcGIS.Core.CIM Namespace / CIMGeometricEffectDashes Class
    CIMGeometricEffectDashes Class Properties
    For a list of all members of this type, see CIMGeometricEffectDashes members.
    Public Properties
     NameDescription
    Public Property Gets or sets the line dash ending position.
    Public Property Gets or sets where the pattern should end relative to the ending point of the geometry. Negative numbers indicate a shift to the left and positive numbers a shift to the right. This property is only applied if the LineDashEnding is set to Custom.
    Public Property Gets or sets the distance for each dash and gap. There can be multiple dash and gap values to form a complex pattern.
    Public Property Gets or sets the setting which determines how the strokes with dash patterns and other patterns (pictures, placement effects) are handled at the end points of the line geometry's segments.
    Public Property Gets or sets the position where the pattern should begin relative to the starting point of the geometry. It shifts the entire pattern along the line the specified distance. Negative values indicate a shift to the left and positive numbers a shift to the right. This property is only applied if LineDashEnding is set to NoConstraint or Custom.
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMGeometricEffect)
    Top
