ArcGIS.Core.Geometry Namespace / ProximityResult Class
    ProximityResult Class Properties
    For a list of all members of this type, see ProximityResult members.
    Public Properties
     NameDescription
    Public Property Gets the distance between the input query point and the nearest point found.
    Public PropertyIs the point rightSide or leftSide? Only relevant if calling GeometryEngine.NearestPoint.
    Public Property Gets the index of the part in which the point was found.
    Public Property Gets the point found.
    Public PropertyGets the index of the point that was found. Only relevant if calling GeometryEngine.NearestVertex, otherwise point index is null.
    Public PropertyGets the segment index of the segment containing the nearest point. The segment index is relative to the part index. For example, if PartIndex = 2 and SegmentIndex = 0, it means segment 0 in part 2. Only relevant if calling GeometryEngine.NearestPoint, otherwise segment index is null.
    Top
