ArcGIS.Core.Data Namespace / AttributeRuleDefinition Class / GetDescription Method
    GetDescription Method (AttributeRuleDefinition)
    Gets the attribute rule description. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDescription() As String
    public string GetDescription()
    Return Value
    The attribute rule description.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
