ArcGIS.Core.Data.Mapping Namespace / AnnotationFeature Class
Members Example
    Represents an annotation feature in an AnnotationFeatureClass.
    Object Model
    AnnotationFeature ClassCIMGraphic ClassGeometry ClassGeometry ClassFeatureClass Class
    Syntax
    Public NotInheritable Class AnnotationFeature
       Inherits ArcGIS.Core.Data.Feature
       Implements System.IDisposable
    public sealed class AnnotationFeature : ArcGIS.Core.Data.Feature, System.IDisposable
    Example
    Rotate or Move the Annotation
      var oid = 1; //ObjectID of the annotation feature to modify
                   // Note: QueuedTask is required to access the AnnotationFeature
        //Don't use 'Shape'....Shape is the bounding box of the annotation text. This is NOT what you want...
        //var insp = new Inspector();
        //insp.Load(annotationLayer, oid);
        //var shape = insp["SHAPE"] as Polygon;
        //...wrong shape...
        //Instead, we must get the TextGraphic from the anno feature.
        //The TextGraphic shape will be the anno baseline...
        QueryFilter qf = new QueryFilter()
          WhereClause = "OBJECTID = 1"
        //annotationLayer is ~your~ Annotation layer
        using var rowCursor = annotationLayer.Search(qf);
        if (rowCursor.MoveNext())
          using (var annoFeature = rowCursor.Current as
          ArcGIS.Core.Data.Mapping.AnnotationFeature)
            var graphic = annoFeature.GetGraphic();
            var textGraphic = graphic as CIMTextGraphic;
            var textLine = textGraphic.Shape as Polyline;
            // rotate the shape 90 degrees
            var origin = GeometryEngine.Instance.Centroid(textLine);
            Geometry rotatedPolyline = GeometryEngine.Instance.Rotate(textLine, origin, System.Math.PI / 2);
            //Move the line 5 "units" in the x and y direction
            //GeometryEngine.Instance.Move(textLine, 5, 5);
            EditOperation op = new EditOperation();
            op.Name = "Change annotation angle";
            op.Modify(annotationLayer, oid, rotatedPolyline);
            op.Execute();
    Get the Annotation Text Graphic
        using var table = annotationLayer.GetTable();
        using var rc = table.Search();
        rc.MoveNext();
        using var af = rc.Current as AnnotationFeature;
        var graphic = af.GetGraphic();
        //Note:
        //var outline_geom = af.GetGraphicOutline();
        //gets the anno text outline geometry...
    Get the Outline Geometry for an Annotation
        //get the first annotation feature...
        //...assuming at least one feature gets selected
        using var fc = annotationLayer.GetFeatureClass();
        using var rc = fc.Search();
        rc.MoveNext();
        //TODO - use the outline...
        //Note:
        //var graphic = annoFeature.GetGraphic();
        //gets the CIMTextGraphic...
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Row
    Requirements
