ArcGIS.Core.Data Namespace / AttributeRuleDefinition Class / GetIsEnabled Method
    GetIsEnabled Method
    Gets if the rule is enabled.
    Syntax
    Public Function GetIsEnabled() As Boolean
    public bool GetIsEnabled()
    Return Value
    A value indicating if the rule is enabled.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
