Public NotInheritable Class LasDataset Inherits ArcGIS.Core.Data.Dataset Implements System.IDisposable
public sealed class LasDataset : ArcGIS.Core.Data.Dataset, System.IDisposable
//Note: Use QueuedTask.Run to run on the MCT
string path = @"d:\Data\LASDataset";
var fileConnection = new FileSystemConnectionPath(new Uri(path), FileSystemDatastoreType.LasDataset);
using (FileSystemDatastore dataStore = new FileSystemDatastore(fileConnection))
string name = "utrecht_tile.lasd"; // can specify with or without the .lasd extension
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.LasDataset>(name))
//Note: Needs QueuedTask to run
using (var tin = tinLayer.GetTinDataset())
using var tinDef = tin.GetDefinition();
Envelope extent = tinDef.GetExtent();
SpatialReference sr = tinDef.GetSpatialReference();
using (terrain = terrainLayer.GetTerrain())
using var terrainDef = terrain.GetDefinition();
Envelope extent = terrainDef.GetExtent();
SpatialReference sr = terrainDef.GetSpatialReference();
using (lasDataset = lasDatasetLayer.GetLasDataset())
using var lasDatasetDef = lasDataset.GetDefinition();
Envelope extent = lasDatasetDef.GetExtent();
SpatialReference sr = lasDatasetDef.GetSpatialReference();
if (lasDataset == null)
throw new ArgumentNullException(nameof(lasDataset));
var lasCP_ds = new LasDatasetLayerCreationParams(lasDataset);
lasCP_ds.Name = "My LAS Layer";
lasCP_ds.IsVisible = false;
// Note: Needs QueuedTask to run
//Create the layer to the LAS dataset
var lasDatasetLayer_ds = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_ds, map);
var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
lasCP_renderers.Name = "My LAS Layer";
lasCP_renderers.IsVisible = false;
// create a point elevation renderer
var ptR = new LasStretchRendererDefinition();
// accept all defaults
// create a simple edge renderer
var edgeR = new TinEdgeRendererDefintion();
// add renderers to dictionary
var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
l_dict.Add(SurfaceRendererTarget.Points, ptR);
l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
// assign dictionary to creation params
lasCP_renderers.RendererDefinitions = l_dict;
var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
System.Object
ArcGIS.Core.CoreObjectsBase
