ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetwork Class / ValidateNetworkTopology Method
    Overload List
    OverloadDescription
    Validates the entire utility network topology. This method must be called on the MCT. Use QueuedTask.Run.
    Validates the utility network topology within the provided extent. This method must be called on the MCT. Use QueuedTask.Run.
    Validates the utility network topology within the provided extent according to the provided validation type. This method must be called on the MCT. Use QueuedTask.Run.
    Validates the utility network topology within the provided extent according to the provided validation type and selection set. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
