ArcGIS.Core.Data.Analyst3D Namespace / LasPoint Class / ToMapPoint Method
Example
    ToMapPoint Method (LasPoint)
    Gets a ArcGIS.Core.Geometry.MapPoint with the X, Y and Z values. The spatial reference of the returned point is set to the spatial reference of the LAS dataset. See LasDatasetDefinition.GetSpatialReference. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function ToMapPoint() As MapPoint
    public MapPoint ToMapPoint()
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Access LAS Points by ID
      // access by ID
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.LasPoint> pts = lasDataset.GetPointByID(123456);
      pts = lasDataset.GetPointByID(123456, envelope);
      ArcGIS.Core.Data.Analyst3D.LasPoint pt = pts.FirstOrDefault();
      var coordsLasPoint = pt.Coordinate3D;
      var mapPointLas = pt.ToMapPoint();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
