Return Value
true if the cursor has successfully advanced to the next point; false if the cursor has passed the end of the collection.
| Exception | Description |
| System.InvalidOperationException | This instance has already called MoveNextArray. Call Reset before using this method. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// search within an extent
ArcGIS.Core.Data.Analyst3D.LasPointFilter pointFilter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
pointFilter.FilterGeometry = envelope;
using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(pointFilter))
while (ptCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current)
// search within an extent and limited to specific classification codes
pointFilter.ClassCodes = new List<int> { 4, 5 };
// Note: Needs QueuedTask to run
// searching on the LasDatasetLayer will honor any LasPointDisplayFilter
// search all points
using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(null))
using ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current;
//Use the point
using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(pointFilter))
//Use the point
//Use the point
