ArcGIS.Core.Data.Analyst3D Namespace / LasPointFilter Class / FilterGeometry Property
Example
    FilterGeometry Property (LasPointFilter)
    Gets and sets a geometry filter. It may be set to an ArcGIS.Core.Geometry.Envelope or a ArcGIS.Core.Geometry.Polygon. Default value is null.
    Syntax
    Public Property FilterGeometry As Geometry
    public Geometry FilterGeometry {get; set;}
    Remarks
    If no geometry is specified, then all points are considered for inclusion by the filter. Otherwise only points inside the geometry are considered for inclusion by the filter. If specified, this will be projected into the spatial reference of the LAS dataset. The Z range, if set, is ignored.
    Example
    Search LAS Points
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.LasPointFilter pointFilter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
      pointFilter.FilterGeometry = envelope;
      using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(pointFilter))
        while (ptCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current)
      // search within an extent and limited to specific classification codes
      pointFilter.ClassCodes = new List<int> { 4, 5 };
    Search using pre initialized arrays
      // search all points
      using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(null))
        int count;
        Coordinate3D[] lasPointsRetrieved = new Coordinate3D[10000];
        while (ptCursor.MoveNextArray(lasPointsRetrieved, null, null, null, out count))
          var pointsLas = lasPointsRetrieved.ToList();
      // use MoveNextArray retrieving coordinates, fileIndex and pointIds
      ArcGIS.Core.Data.Analyst3D.LasPointFilter filter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
      filter.FilterGeometry = envelope;
      using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(filter))
        int count;
        Coordinate3D[] lasPointsRetrieved = new Coordinate3D[50000];
        int[] fileIndexes = new int[50000];
        double[] pointIds = new double[50000];
        while (ptCursor.MoveNextArray(lasPointsRetrieved, null, fileIndexes, pointIds, out count))
    Search for LAS Points
      // Note: Needs QueuedTask to run
        // searching on the LasDatasetLayer will honor any LasPointDisplayFilter
        using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(null))
            using ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current;
            //Use the point
        using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(pointFilter))
            //Use the point
            //Use the point
    Requirements
    ArcGIS Pro version: 3.2 or higher.
