ArcGIS.Core.Data.Analyst3D Namespace / SurfaceConstraint Class
Members Example
    Represents a surface constraint in a LAS dataset. See GetSurfaceConstraints.
    Syntax
    Public NotInheritable Class SurfaceConstraint
    public sealed class SurfaceConstraint
    Remarks
    Surface constraints are features whose geometry capture or define the characteristics of the surface. Breaklines, water polygons, or area clipping boundaries are all examples of surface constraints. Surface constraints can be feature classes or shapefiles.
    Example
    Get Surface Constraint information from a LAS Dataset
      var constraintCount = lasDataset.GetSurfaceConstraintCount();
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.SurfaceConstraint> constraints = lasDataset.GetSurfaceConstraints();
      foreach (var constraint in constraints)
        var dsName = constraint.DataSourceName;
        var wksPath = constraint.WorkspacePath;
        var heightField = constraint.HeightField;
        var surfaceType = constraint.SurfaceType;
    Active Surface Constraints
      // Note: Needs QueuedTask to run
        var activeSurfaceConstraints = lasDatasetLayer.GetActiveSurfaceConstraints();
        // clear all surface constraints (i.e. none are active)
        lasDatasetLayer.SetActiveSurfaceConstraints(null);
        // set all surface constraints active
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          var surfaceConstraints = lasDataset.GetSurfaceConstraints();
          var names = surfaceConstraints.Select(sc => sc.DataSourceName).ToList();
          lasDatasetLayer.SetActiveSurfaceConstraints(names);
    Inheritance Hierarchy
    System.Object
    Requirements
    ArcGIS Pro version: 3.2 or higher.
