ArcGIS.Core.Data.Analyst3D Namespace / Terrain Class
Members Example
    Terrain Class
    Represents a terrain dataset.
    Object Model
    Terrain ClassDatastore ClassTerrainDefinition ClassEnvelope ClassFeatureDataset ClassTerrainTileProperties Class
    Syntax
    Public NotInheritable Class Terrain
       Inherits ArcGIS.Core.Data.Dataset
       Implements System.IDisposable
    public sealed class Terrain : ArcGIS.Core.Data.Dataset, System.IDisposable
    Remarks
    A terrain is a multiresolution, TIN-based surface built from measurements stored as features in a geodatabase. They're typically made from lidar, sonar, and photogrammetric sources. Terrains have participating feature classes and rules. See TerrainDataSource .
    Terrain data is organized for fast retrieval. This organization involves the creation of terrain pyramids that are used to quickly retrieve only the data necessary to construct a surface of the required level of detail (LOD) for a given area of interest (AOI) from the database. See TerrainPyramidLevel.
    Example
    Open a Terrain
      //Note: Use QueuedTask.Run to run on the MCT
      string path = @"d:\Data\Terrain\filegdb_Containing_A_Terrain.gdb";
      var fileConnection = new FileGeodatabaseConnectionPath(new Uri(path));
      using (Geodatabase dataStore = new Geodatabase(fileConnection))
        string dsName = "nameOfTerrain";
        using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.Terrain>(dsName))
    Retrieve dataset objects
      //Note: Needs QueuedTask to run
        using (var tin = tinLayer.GetTinDataset())
          using var tinDef = tin.GetDefinition();
          Envelope extent = tinDef.GetExtent();
          SpatialReference sr = tinDef.GetSpatialReference();
        using (terrain = terrainLayer.GetTerrain())
          using var terrainDef = terrain.GetDefinition();
          Envelope extent = terrainDef.GetExtent();
          SpatialReference sr = terrainDef.GetSpatialReference();
        using (lasDataset = lasDatasetLayer.GetLasDataset())
          using var lasDatasetDef = lasDataset.GetDefinition();
          Envelope extent = lasDatasetDef.GetExtent();
          SpatialReference sr = lasDatasetDef.GetSpatialReference();
    Create a TerrainLayer from a dataset
      var terrainCP_ds = new TerrainLayerCreationParams(terrain);
      terrainCP_ds.Name = "My Terrain Layer";
      terrainCP_ds.IsVisible = true;
      //Create the layer to the terrain
      // Note: Needs QueuedTask to run
        var terrainLayer_ds = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_ds, map);
    Create a TerrainLayer with renderers
      var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
      terrainCP_renderers.Name = "My LAS Layer";
      terrainCP_renderers.IsVisible = true;
      // define the edge type renderer - use defaults
      var edgeRD = new TinBreaklineRendererDefinition();
      // define the face/surface renderer
      var faceRD = new TinFaceClassBreaksRendererDefinition();
      faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // define the dirty area renderer - use defaults
      var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
      // add renderers to dictionary
      var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
      t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
      t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
      // assign dictionary to creation params
      terrainCP_renderers.RendererDefinitions = t_dict;
        var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
    Requirements
    ArcGIS Pro version: 3.2 or higher.
