Public NotInheritable Class TinDataset Inherits ArcGIS.Core.Data.Dataset Implements System.IDisposable
public sealed class TinDataset : ArcGIS.Core.Data.Dataset, System.IDisposable
//Note: This snippet requires to be run on the MCT (Main CIM Thread)
string path = @"d:\Data\Tin";
var fileConnection = new FileSystemConnectionPath(new Uri(path), FileSystemDatastoreType.Tin);
using (FileSystemDatastore dataStore = new FileSystemDatastore(fileConnection))
// TIN is in a folder at d:\Data\Tin\TinDataset
string dsName = "TinDataset";
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(dsName))
//Do something with the dataset
//Note: Needs QueuedTask to run
using (var tin = tinLayer.GetTinDataset())
using var tinDef = tin.GetDefinition();
Envelope extent = tinDef.GetExtent();
SpatialReference sr = tinDef.GetSpatialReference();
using (terrain = terrainLayer.GetTerrain())
using var terrainDef = terrain.GetDefinition();
Envelope extent = terrainDef.GetExtent();
SpatialReference sr = terrainDef.GetSpatialReference();
using (lasDataset = lasDatasetLayer.GetLasDataset())
using var lasDatasetDef = lasDataset.GetDefinition();
Envelope extent = lasDatasetDef.GetExtent();
SpatialReference sr = lasDatasetDef.GetSpatialReference();
var tinCP_ds = new TinLayerCreationParams(tinDataset);
tinCP_ds.Name = "My TIN Layer";
tinCP_ds.IsVisible = false;
//Create the layer to the TIN
// Note: Needs QueuedTask to run
var tinLayer_ds = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_ds, map);
var tinCP_renderers = new TinLayerCreationParams(tinDataset)
Name = "My TIN layer",
IsVisible = true
// define the node renderer - use defaults
var node_rd = new TinNodeRendererDefinition();
// define the face/surface renderer
var face_rd = new TinFaceClassBreaksRendererDefinition();
face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
// accept default color ramp, breakCount
// set up the renderer dictionary
var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
{ SurfaceRendererTarget.Points, node_rd },
{ SurfaceRendererTarget.Surface, face_rd }
// assign the dictionary to the creation params
tinCP_renderers.RendererDefinitions = rendererDict;
// create the layer
var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, MapView.Active.Map);
System.Object
ArcGIS.Core.CoreObjectsBase
