ArcGIS.Core.Data.Analyst3D Namespace / TinEdge Class / GetNextEdgeInTriangle Method
Example
    Gets the next edge in the triangle. The next edge is in the clockwise direction. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetNextEdgeInTriangle() As TinEdge
    public TinEdge GetNextEdgeInTriangle()
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    TIN Edges
      // nodes of the edge
      var nodes = edge.Nodes;
      // edge geometry
      polyline = edge.ToPolyline();
      // edge length
      var length = edge.Length;
      // is the edge "inside"
      var isInsideEdge = edge.IsInsideDataArea;
      // edge type - regular/hard/soft
      var edgeType = edge.EdgeType;
      // get next (clockwise) edge in the triangle
      var nextEdge = edge.GetNextEdgeInTriangle();
      // get previous (anti-clockwise) edge in the triangle
      var prevEdge = edge.GetPreviousEdgeInTriangle();
      // get opposite edge
      var oppEdge = edge.GetNeighbor();
      // get left triangle
      var leftTriangle = edge.LeftTriangle;
      // get right triangle
      var rightTriangle = edge.RightTriangle;
    Requirements
    ArcGIS Pro version: 3.2 or higher.
