ArcGIS.Core.Data.Analyst3D Namespace / TinEdgeFilter Class / FilterByEdgeType Property
Example
    Gets and sets whether the EdgeType property is used in the filter. Default value is false.
    Syntax
    Public Property FilterByEdgeType As Boolean
    public bool FilterByEdgeType {get; set;}
    Remarks
    If false, all edge types will be found.
    Example
    Search for TIN Edges
      // search all single edges that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(null))
        while (edgeCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinEdge edgeCurrent = edgeCursor.Current)
            // do something with the edge
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
      edgeFilter.FilterEnvelope = envelope;
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(edgeFilter))
      // search all "inside" edges
      edgeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
      // search for hard edges
      edgeFilter.FilterByEdgeType = true;
      edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
    Search for TIN Nodes, Edges, Triangles
      // Note: Needs QueuedTask to run
        // search all "inside" nodes
        using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(null))
          while (nodeCursor.MoveNext())
            using ArcGIS.Core.Data.Analyst3D.TinNode node = nodeCursor.Current;
            //Use the node
        // search "inside" nodes with an extent
        ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
        nodeFilter.FilterEnvelope = envelope;
        using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(nodeFilter))
            //use the node
        // search for super nodes only
        var supernodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
        supernodeFilter.FilterEnvelope = tinLayer.GetTinDataset().GetSuperNodeExtent();
        supernodeFilter.DataElementsOnly = false;
        supernodeFilter.SuperNode = true;
            //Use the node
        // search all edges within an extent
        //    this could include outside or edges attached to super nodes depending upon the extent
        ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilterAll = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
        edgeFilterAll.FilterEnvelope = envelope;
        edgeFilterAll.DataElementsOnly = false;
        using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilterAll))
            using ArcGIS.Core.Data.Analyst3D.TinEdge edge = edgeCursor.Current;
            //Use the edge
        // search for hard edges in the TIN
        var edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
        using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilter))
            //Use the edge
        // search for "inside" triangles in an extent
        ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
        triangleFilter.FilterEnvelope = envelope;
        triangleFilter.DataElementsOnly = true;
        using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleCursor = tinLayer.SearchTriangles(triangleFilter))
          while (triangleCursor.MoveNext())
            using ArcGIS.Core.Data.Analyst3D.TinTriangle triangle = triangleCursor.Current;
            //use the triangle
    Requirements
    ArcGIS Pro version: 3.2 or higher.
