ArcGIS.Core.Data.Analyst3D Namespace / TinFilter Class / FilterEnvelope Property
Example
    Gets and sets an envelope filter. Default value is null meaning that the envelope searched is the TIN's data area, See TinDataset.GetDataArea.
    Syntax
    Public Property FilterEnvelope As Envelope
    public Envelope FilterEnvelope {get; set;}
    Remarks
    Use this to specify a specific area to search rather than the TIN's data area. If specified, the envelope will be projected into the spatial reference of the TIN dataset.
    Example
    Search for TIN Nodes
      // search all nodes that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorsearch = tinDataset.SearchNodes(null))
        while (nodeCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinNode nodeCurrent = nodeCursor.Current)
            // do something with the node
      // search within an extent
      ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
      nodeFilter.FilterEnvelope = envelope; //or use any other appropriate envelope
      using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorSearch = tinDataset.SearchNodes(nodeFilter))
      // search all "inside" nodes
      nodeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
      // search for super nodes only
      nodeFilter.FilterEnvelope = tinDataset.GetSuperNodeExtent();
      nodeFilter.SuperNode = true;
    Search for TIN Edges
      // search all single edges that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(null))
        while (edgeCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinEdge edgeCurrent = edgeCursor.Current)
            // do something with the edge
      ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
      edgeFilter.FilterEnvelope = envelope;
      using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(edgeFilter))
      // search all "inside" edges
      edgeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
      // search for hard edges
      edgeFilter.FilterByEdgeType = true;
      edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
    Search for TIN Triangles
      // search all triangles that intersect the data extent
      using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(null))
        while (triangleCursor.MoveNext())
          using (ArcGIS.Core.Data.Analyst3D.TinTriangle triangleCurrent = triangleCursor.Current)
      ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
      triangleFilter.FilterEnvelope = envelope;
      using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(triangleFilter))
      // search all "inside" triangles
      triangleFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
    Search for TIN Nodes, Edges, Triangles
      // Note: Needs QueuedTask to run
        using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(null))
            using ArcGIS.Core.Data.Analyst3D.TinNode node = nodeCursor.Current;
            //Use the node
        // search "inside" nodes with an extent
        using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(nodeFilter))
            //use the node
        var supernodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
        supernodeFilter.FilterEnvelope = tinLayer.GetTinDataset().GetSuperNodeExtent();
        supernodeFilter.DataElementsOnly = false;
        supernodeFilter.SuperNode = true;
            //Use the node
        // search all edges within an extent
        //    this could include outside or edges attached to super nodes depending upon the extent
        ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilterAll = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
        edgeFilterAll.FilterEnvelope = envelope;
        edgeFilterAll.DataElementsOnly = false;
        using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilterAll))
            using ArcGIS.Core.Data.Analyst3D.TinEdge edge = edgeCursor.Current;
            //Use the edge
        // search for hard edges in the TIN
        var edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
        using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilter))
            //Use the edge
        // search for "inside" triangles in an extent
        triangleFilter.DataElementsOnly = true;
        using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleCursor = tinLayer.SearchTriangles(triangleFilter))
            using ArcGIS.Core.Data.Analyst3D.TinTriangle triangle = triangleCursor.Current;
            //use the triangle
    Requirements
    ArcGIS Pro version: 3.2 or higher.
