ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / GetAdjacentNodeIndices Method
    Gets all the node indices that are next to this node; that is that are connected to this node by TIN edges. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetAdjacentNodeIndices() As IReadOnlyList(Of Integer)
    public IReadOnlyList<int> GetAdjacentNodeIndices()
    Return Value
    A IReadOnlyList of node indices.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
