ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / ToMapPoint Method
Example
    ToMapPoint Method (TinNode)
    Gets a ArcGIS.Core.Geometry.MapPoint with the X, Y and Z values. The spatial reference of the returned point is set to the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference.
    Syntax
    Public Function ToMapPoint() As MapPoint
    public MapPoint ToMapPoint()
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    TIN Nodes
      // is the node "inside"
      var isInsideNode = node.IsInsideDataArea;
      // get all other nodes connected to "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinNode> adjNodes = node.GetAdjacentNodes();
      // get all edges that share "node" as a from node.
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinEdge> edges = node.GetIncidentEdges();
      // get all triangles that share "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinTriangle> triangles = node.GetIncidentTriangles();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
