ArcGIS.Core.Data.Analyst3D Namespace / TinNode Class / Coordinate3D Property
Example
    Coordinate3D Property (TinNode)
    Gets a ArcGIS.Core.Geometry.Coordinate3D structure with the X, Y, and Z values. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public ReadOnly Property Coordinate3D As Coordinate3D
    public Coordinate3D Coordinate3D {get;}
    Example
    TIN Nodes
      // is the node "inside"
      var isInsideNode = node.IsInsideDataArea;
      // get all other nodes connected to "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinNode> adjNodes = node.GetAdjacentNodes();
      // get all edges that share "node" as a from node.
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinEdge> edges = node.GetIncidentEdges();
      // get all triangles that share "node"
      IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinTriangle> triangles = node.GetIncidentTriangles();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
