Public ReadOnly Property Operation As EditOperation
public EditOperation Operation {get;}
// attach an event handler to receive notifications when a new row is created in the // associated table of the first feature layer found in the active map. Use this method to enable custom logic in // response to row creation events within your ArcGIS Pro add-in. // subscribe to the RowCreatedEvent Table table = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable(); RowCreatedEvent.Subscribe(rowChangedEventArgs => { // RowEvent callbacks are always called on the QueuedTask so there is no need // to wrap your code within a QueuedTask.Run lambda. // get the edit operation var parentEditOp = rowChangedEventArgs.Operation; // set up some attributes var attribs = new Dictionary<string, object> { { "Layer", "Parcels" }, { "Description", "objectId: " + rowChangedEventArgs.Row.GetObjectID().ToString() + " " + DateTime.Now.ToShortTimeString() } }; //create a record in an audit table var sTable = MapView.Active.Map.FindStandaloneTables("EditHistory")[0]; var table = sTable.GetTable(); parentEditOp.Create(table, attribs); }, table);
// Attach an event handler to the <see cref="ArcGIS.Desktop.Editing.Events.RowCreatedEvent"/> for the table associated with the first <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> in the active map. Use this method to monitor when new rows are created // in that table, enabling custom logic to be executed in response to record creation events. Table firstTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable(); RowCreatedEvent.Subscribe(rowChangedEventArgs => { // RowEvent callbacks are always called on the QueuedTask so there is no need // to wrap your code within a QueuedTask.Run lambda. // update a separate table not in the map when a row is created // You MUST use the ArcGIS.Core.Data API to edit the table. Do NOT // use a new edit operation in the RowEvent callbacks try { // get the edit operation var parentEditOp = rowChangedEventArgs.Operation; // set up some attributes var attribs = new Dictionary<string, object> { { "Description", "objectId: " + rowChangedEventArgs.Row.GetObjectID().ToString() + " " + DateTime.Now.ToShortTimeString() } }; // update Notes table with information about the new feature using var geoDatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(Project.Current.DefaultGeodatabasePath))); using var table = geoDatabase.OpenDataset<Table>("Notes"); parentEditOp.Create(table, attribs); } catch (Exception e) { throw new Exception($@"Error in OnRowCreated for objectId: {rowChangedEventArgs.Row.GetObjectID()} : {e}"); } }, firstTable);
// Subscribe to the <see cref="ArcGIS.Desktop.Editing.Events.RowChangedEvent"/> for // the first <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> in the active map. The event handler can be used to // respond to changes in rows within the table, such as modifications or updates. Table changeTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable(); RowChangedEvent.Subscribe(rowChangedEventArgs => { // set the last row changed guid when you execute the Row.Store method // used for re-entry checking Guid _lastEdit = new(); // RowEvent callbacks are always called on the QueuedTask so there is no need // to wrap your code within a QueuedTask.Run lambda. //example of modifying a field on a row that has been created var parentEditOp = rowChangedEventArgs.Operation; // avoid recursion if (_lastEdit != rowChangedEventArgs.Guid) { //update field on change parentEditOp.Modify(rowChangedEventArgs.Row, "ZONING", "New"); _lastEdit = rowChangedEventArgs.Guid; } }, changeTable);
