Public Function GetNormal() As Coordinate3D
public Coordinate3D GetNormal()
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
// nodes, edges of the triangle
var triNnodes = triangle.Nodes;
var triEdges = triangle.Edges;
// triangle geometry
polygon = triangle.ToPolygon();
// triangle length
var triLength = triangle.Length;
// triangle area
var triArea = triangle.Area;
// is the triangle "inside"
var isInsideTriangle = triangle.IsInsideDataArea;
// triangle aspect and slope (radians)
var aspect = triangle.Aspect;
var slope = triangle.Slope;
// get centroid
var centroid = triangle.GetCentroid();
// get normal
var normal = triangle.GetNormal();
// get adjacent triangles
var adjTriangles = triangle.GetAdjacentTriangles();
// get area of triangle that falls between the z values
double minZ = 1.0;
double maxZ = 3.0;
IReadOnlyList<Coordinate3D> coords = triangle.GetPointsBetweenZs(minZ, maxZ);
