Public Overloads Sub SetDisplayFilter( _ ByVal filter As LasPointDisplayFilter _ )
public void SetDisplayFilter( LasPointDisplayFilter filter )
Parameters
- filter
- A LasPointDisplayFilter.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentNullException | filter cannot be null. |
// Note: Needs QueuedTask to run
// get the current display filter
LasPointDisplayFilter ptFilter = lasDatasetLayer.GetDisplayFilter();
// display only ground points
lasDatasetLayer.SetDisplayFilter(LasPointDisplayFilterType.Ground);
// display first return points
lasDatasetLayer.SetDisplayFilter(LasPointDisplayFilterType.FirstReturnPoints);
// set display filter to a set of classification codes
List<int> classifications = new List<int>() { 4, 5, 7, 10 };
lasDatasetLayer.SetDisplayFilter(classifications);
// set display filter to a set of returns
List<ArcGIS.Core.Data.Analyst3D.LasReturnType> returns = new List<ArcGIS.Core.Data.Analyst3D.LasReturnType>()
{ ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnFirstOfMany};
lasDatasetLayer.SetDisplayFilter(returns);
// set up a display filter
var newDisplayFilter = new LasPointDisplayFilter();
newDisplayFilter.Returns = new List<ArcGIS.Core.Data.Analyst3D.LasReturnType>()
{ ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnFirstOfMany, ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnLastOfMany};
newDisplayFilter.ClassCodes = new List<int>() { 2, 4 };
newDisplayFilter.KeyPoints = true;
newDisplayFilter.WithheldPoints = false;
newDisplayFilter.SyntheticPoints = false;
newDisplayFilter.NotFlagged = false;
