Parameters
- enabled
- The eye dome lighting enabled state.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
// Note: Needs QueuedTask to run
// get current EDL settings
bool isEnabled = lasDatasetLayer.IsEyeDomeLightingEnabled;
var radius = lasDatasetLayer.EyeDomeLightingRadius;
var strength = lasDatasetLayer.EyeDomeLightingStrength;
// set EDL values
lasDatasetLayer.SetEyeDomeLightingEnabled(true);
lasDatasetLayer.SetEyeDomeLightingStrength(65.0);
lasDatasetLayer.SetEyeDomeLightingRadius(2.0);
