ArcGIS.Desktop.Mapping Namespace / LasDatasetLayer Class / SetEyeDomeLightingRadius Method
The eye dome lighting radius. The value must be between 1 and 5 inclusive.
Example
    SetEyeDomeLightingRadius Method (LasDatasetLayer)
    Sets the Eye Dome Lighting (EDL) radius value. The EDL radius controls the width of effects. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetEyeDomeLightingRadius( _
       ByVal value As Double _
    public void SetEyeDomeLightingRadius(
       double value
    Parameters
    value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    The radius value must be between 1 and 5 inclusive.
    Remarks
    The EDL radius is a value between 1 and 5 inclusive. The default value is 2 pixels wide. A larger radius will slow down performance. Ensure that IsEyeDomeLightingEnabled is true for this value to have effect.
    Example
    Eye Dome Lighting
      // Note: Needs QueuedTask to run
        // get current EDL settings
        bool isEnabled = lasDatasetLayer.IsEyeDomeLightingEnabled;
        var radius = lasDatasetLayer.EyeDomeLightingRadius;
        var strength = lasDatasetLayer.EyeDomeLightingStrength;
        // set EDL values
        lasDatasetLayer.SetEyeDomeLightingEnabled(true);
        lasDatasetLayer.SetEyeDomeLightingStrength(65.0);
        lasDatasetLayer.SetEyeDomeLightingRadius(2.0);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
