ArcGIS.Desktop.Mapping Namespace / LasDatasetLayer Class / SetEyeDomeLightingStrength Method
The eye dome lighting strength. The value must be between 0 and 100 inclusive.
Example
    SetEyeDomeLightingStrength Method (LasDatasetLayer)
    Sets the Eye Dome Lighting (EDL) strength value. The EDL strength adjusts the intensity of the resulting effects. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetEyeDomeLightingStrength( _
       ByVal value As Double _
    public void SetEyeDomeLightingStrength(
       double value
    Parameters
    value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    The strength value must be between 0 and 100 inclusive.
    Remarks
    The EDL strength value is a percentage (that is a value between 0 and 100). EDL is disabled when the value is set to 0. The default value is 50. A larger value will give you a stronger perception of the depth. Ensure that IsEyeDomeLightingEnabled is true for this value to have effect.
    Example
    Eye Dome Lighting
      // Note: Needs QueuedTask to run
        // get current EDL settings
        bool isEnabled = lasDatasetLayer.IsEyeDomeLightingEnabled;
        var radius = lasDatasetLayer.EyeDomeLightingRadius;
        var strength = lasDatasetLayer.EyeDomeLightingStrength;
        // set EDL values
        lasDatasetLayer.SetEyeDomeLightingEnabled(true);
        lasDatasetLayer.SetEyeDomeLightingStrength(65.0);
        lasDatasetLayer.SetEyeDomeLightingRadius(2.0);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
