ArcGIS.Desktop.Mapping Namespace / LineOfSightParams Class / TargetHeightOffset Property
Example
    Gets and sets the vertical offset to apply to the target point (in the vertical unit of measure of the surface). Default value is 0.0.
    Syntax
    Public Property TargetHeightOffset As Double
    public double TargetHeightOffset {get; set;}
    Example
    Get Line of Sight
      tinLayer = null;
      MapPoint observerPoint = null;
      MapPoint targetPoint = null;
      CIMPointSymbol obstructionPointSymbol = null;
      CIMLineSymbol visibleLineSymbol = null;
      CIMLineSymbol invisibleLineSymbol = null;
      var losParams = new LineOfSightParams();
      losParams.ObserverPoint = observerPoint;
      losParams.TargetPoint = targetPoint;
      // add offsets if appropriate
      // losParams.ObserverHeightOffset = observerOffset;
      // losParams.TargetHeightOffset = targerOffset;
      // add obstruction feature class if appropriate (multipatch)
      //losParams.ObstructionsMultipatchFeatureClass = obsFeatureClass;
      // set output spatial reference
      losParams.OutputSpatialReference = MapView.Active.Map.SpatialReference;
      LineOfSightResult results = null;
      try
        // Note: Needs QueuedTask to run
          if (tinLayer.CanGetLineOfSight(losParams))
            results = tinLayer.GetLineOfSight(losParams);
      catch (Exception)
        // handle exception
      if (results != null)
        bool targetIsVisibleFromObserverPoint = results.IsTargetVisibleFromObserverPoint;
        //These properties are not used. They will always be false
        // results.IsTargetVisibleFromVisibleLine;
        // results.IsTargetVisibleFromInvisibleLine;
        if (results.VisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, visibleLineSymbol.MakeSymbolReference());
        if (results.InvisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, invisibleLineSymbol.MakeSymbolReference());
        if (results.ObstructionPoint != null)
          MapView.Active.AddOverlay(results.ObstructionPoint, obstructionPointSymbol.MakeSymbolReference());
    Requirements
    ArcGIS Pro version: 3.2 or higher.
