ArcGIS.Desktop.Mapping Namespace / SurfaceLayer Class / GetRenderers Method
Example
    GetRenderers Method
    Gets the set of renderers used to draw the surface layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetRenderers() As IReadOnlyList(Of CIMTinRenderer)
    public IReadOnlyList<CIMTinRenderer> GetRenderers()
    Return Value
    A ReadOnlyList of CIMTinRenderer.
    Exceptions
    ExceptionDescription
    Example
    Get Renderers
      // Note: Needs QueuedTask to run
        // get the list of renderers
        IReadOnlyList<CIMTinRenderer> renderers = surfaceLayer.GetRenderers();
        // get the renderers as a dictionary
        Dictionary<SurfaceRendererTarget, CIMTinRenderer> dict = surfaceLayer.GetRenderersAsDictionary();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
