ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetwork Class / GetDiagramManager Method
Example
    GetDiagramManager Method (UtilityNetwork)
    Gets the associated/contained ArcGIS.Core.Data.NetworkDiagrams.DiagramManager of the network. This method must be called on the MCT. Use QueuedTask.Run
    Syntax
    Public Function GetDiagramManager() As DiagramManager
    public DiagramManager GetDiagramManager()
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get the Diagram Manager
      static void GetDiagramManager(UtilityNetwork utilityNetwork)
        // Get the DiagramManager from the utility network
        using (DiagramManager diagramManager = utilityNetwork.GetDiagramManager())
          // Use the diagram manager...
    Get Network Diagrams
      static void GetDiagram(UtilityNetwork utilityNetwork, IEnumerable<Guid> globalIDs)
        Envelope extentOfInterest = MapView.Active.Map.GetDefaultExtent();
          // Get all the diagrams
          IReadOnlyList<NetworkDiagram> diagrams = diagramManager.GetNetworkDiagrams();
          // Get a diagram by name
          NetworkDiagram diagram = diagramManager.GetNetworkDiagram(_diagramName);
          // Get diagrams by extent
          diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest);
          // Get diagrams from a set of utility network feature GlobalIDs
          diagrams = diagramManager.GetNetworkDiagrams(globalIDs);
          // Get diagrams from a set of utility network feature GlobalIDs within an extent
          diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest, globalIDs);
    Get a list of Network Diagrams with inconsistent ConsistencyState
      static List<NetworkDiagram> GetInconsistentDiagrams(UtilityNetwork utilityNetwork)
          List<NetworkDiagram> networkDiagrams = new List<NetworkDiagram>();
          // Loop through the network diagrams in the diagram manager
          foreach (NetworkDiagram diagram in diagramManager.GetNetworkDiagrams())
            NetworkDiagramInfo diagramInfo = diagram.GetDiagramInfo();
            // If the diagram is not a system diagram and is in an inconsistent state, add it to our list
            if (!diagramInfo.IsSystem &&
                diagram.GetConsistencyState() != NetworkDiagramConsistencyState.DiagramIsConsistent)
              networkDiagrams.Add(diagram);
            else
              diagram.Dispose(); // If we are not returning it we need to Dispose it
          return networkDiagrams;
    Get Diagram Templates
      // Get all the diagram templates or a template by name
      static void RetrieveDiagramTemplates(UtilityNetwork utilityNetwork)
        string templateName = "ElectricNetworkTemplate";
        using DiagramManager diagramManager = utilityNetwork.GetDiagramManager();
        // Get all templates
        IReadOnlyList<DiagramTemplate> templates = diagramManager.GetDiagramTemplates();
        // Get a template by name
        DiagramTemplate template = diagramManager.GetDiagramTemplate(templateName);
    Get Network Diagrams from a Diagram Template
      // Get all the network diagrams from a template or a diagram by name
      static void GetNetworkDiagramFromDiagramTemplates(UtilityNetwork utilityNetwork)
          // Get the first templates
          DiagramTemplate template = diagramManager.GetDiagramTemplates().FirstOrDefault();
          // Get the network diagrams fromt he template
          IEnumerable<NetworkDiagram> diagrams = template.GetNetworkDiagrams();
          // Get a network diagram by name
          NetworkDiagram diagram = template.GetNetworkDiagram(_diagramName);
    Create a Network Diagram
      // Create a network diagram from a template and a set of utility network feature GlobalIDs
      static void CreateNetworkDiagram(UtilityNetwork utilityNetwork, IEnumerable<Guid> globalIDs)
          // Get the template
          DiagramTemplate template = diagramManager.GetDiagramTemplate(TemplateName);
          // Create the diagram
          NetworkDiagram diagram = diagramManager.CreateNetworkDiagram(template, globalIDs);
    Get Network Diagram Information as JSON string
      static void GetDiagramContent(UtilityNetwork utilityNetwork)
          NetworkDiagram diagram = diagramManager.GetNetworkDiagram(TemplateName);
          string jsonContent = diagram.GetContent(true, true, true, true);
    Requirements
