ArcGIS.Desktop.Mapping Namespace / TinLayer Class / SearchNodes Method
Filter by parameters. See ArcGIS.Core.Data.Analyst3D.TinNodeFilter. If null, then all nodes are retrieved.
Example
    SearchNodes Method (TinLayer)
    Retrieves the nodes in the TIN that satisfy the criteria set in the filter. If no filter is set, all nodes will be retrieved. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function SearchNodes( _
       ByVal filter As TinNodeFilter _
    ) As TinNodeCursor
    public TinNodeCursor SearchNodes(
       TinNodeFilter filter
    Parameters
    filter
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Analyst3D.TinNodeCursor in either a using statement or a finally block.
    Example
    Search for TIN Nodes, Edges, Triangles
      // Note: Needs QueuedTask to run
        // search all "inside" nodes
        using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(null))
          while (nodeCursor.MoveNext())
            using ArcGIS.Core.Data.Analyst3D.TinNode node = nodeCursor.Current;
            //Use the node
        // search "inside" nodes with an extent
        ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
        nodeFilter.FilterEnvelope = envelope;
        using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(nodeFilter))
            //use the node
        // search for super nodes only
        var supernodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
        supernodeFilter.FilterEnvelope = tinLayer.GetTinDataset().GetSuperNodeExtent();
        supernodeFilter.DataElementsOnly = false;
        supernodeFilter.SuperNode = true;
            //Use the node
        // search all edges within an extent
        //    this could include outside or edges attached to super nodes depending upon the extent
        ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilterAll = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
        edgeFilterAll.FilterEnvelope = envelope;
        edgeFilterAll.DataElementsOnly = false;
        using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilterAll))
          while (edgeCursor.MoveNext())
            using ArcGIS.Core.Data.Analyst3D.TinEdge edge = edgeCursor.Current;
            //Use the edge
        // search for hard edges in the TIN
        var edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
        edgeFilter.FilterByEdgeType = true;
        edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
        using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilter))
            //Use the edge
        // search for "inside" triangles in an extent
        ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
        triangleFilter.FilterEnvelope = envelope;
        triangleFilter.DataElementsOnly = true;
        using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleCursor = tinLayer.SearchTriangles(triangleFilter))
          while (triangleCursor.MoveNext())
            using ArcGIS.Core.Data.Analyst3D.TinTriangle triangle = triangleCursor.Current;
            //use the triangle
    Requirements
    ArcGIS Pro version: 3.2 or higher.
