ArcGIS.Desktop.Mapping Namespace / LasAttributeType Enumeration
Example Example
    Attributes used to define a ArcGIS.Core.CIM.CIMLASUniqueValueRenderer.
    Syntax
    Members
    MemberDescription
    Classification Classification codes.
    None None.
    NumberOfReturns Number of returns.
    PointSourceID Point source ID.
    ReturnNumber Return number.
    UserData User data.
    Example
    LAS Points Classification Unique Value Renderer
      var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
      // accept the defaults for color ramp, symbolTemplate, symbol scale factor
      if (lasDatasetLayer == null)
        return;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Returns Unique Value Renderer
      var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
      lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
      lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.LasAttributeType
    Requirements
    ArcGIS Pro version: 3.2 or higher.
